How to erase record of meter?
arima
Post by arima »
I would like to change the setting position of Omnimeter and to newly record in meter.
Old record of meter is so obstructive.
Re: How to erase record of meter?
Hello Arima,
It sounds like you would like to reset the Meter's recorded kWh to zero. This is not possible with our meters. In order to provide revenue grade metering and to prevent tampering, we cannot reset the "Total kWh" to zero.
Our new Omnimeter Pulse v.4 has a "Resettable kWh" Register. You can reset this register to zero. You could reset it once per month, or whenever the meter gets moved to a new location. This is like a Trip Odometer on a car. It still has the main or "Total kWh" register that is not resettable.
Here is a link to the Omnimeter Pulse v.4: http://www.ekmmetering.com/ekm-metering ... pulse.html
