Connecting EKM Push to 2 each single phase 400 amp services
Searchman
Post by Searchman »
I have two 400 amp single phase services serving one residence. I currently am using 1- Omnimeter for each service. Do I need to install two Push meters or can I daisy chain the two omnimeters together and receive readings specific to each service?
Re: Connecting EKM Push to 2 each single phase 400 amp servi
If you have 2 EKM Omnimeters you will only need 1 EKM Push gateway to connect to both of your meters. You can have up to 256 EKM Omnimeters connected to 1 EKM Push gateway. The data will come in as 2 separate streams each pertaining to it's own meter number.
In our sample case 10068 and 10054 are 2 separate meters on the same EKM Push account. You can view each one separately. You can have an unlimited number of meters in your account.
