What is the significance of the arrow on the cts? Thanks in advance.
Roy
arrow on ct
Re: arrow on ct
Hello Roy,
Welcome to the forum.
The arrow on our CTs indicates the load. The CTs should be installed with the arrow pointing towards the load or away from the grid (generation). Our Omnimeters keep track of kWh coming from the grid and towards the grid (in the case of solar generation) as two separate values.
If your CTs and Omnimeter are properly installed and you do not have on-site generation (solar) then you should not see any kWh on Register 2 (reverse kWh).
Let us know if you have any questions.
