is there a memory?
saadhamad
is there a memory?
Post by saadhamad »
Hi every one,
I bought Ekm-OmniMeter v.3 , but I don’t know how to recover the data in case of having no wifi.
Also, if there is a memory, how big is it, how long it takes to be full or does it over read the older data?
Re: is there a memory?
Hello saadhamad, welcome to the forum.
The Omnimeter v.3 only stores Total kWh, Reverse kWh, Total kWh in 4 TOU periods, Reverse kWh in 4 TOU periods. It also stores 6 months of Total and Reverse kWh values taken on the last day of each month (these values are only accessible via the EKM Dash using a USB or iSerial converter) It does not store real-time values like watts, amps, volts or power factor. If you want a full dataset (a read a minute for example) you will have to connect your EKM Omnimeter to either a computer running the EKM Dash software, or to the EKM Push system.
