Hello Wouter,
The "Complete Guide to EKM Metering is a good place to start:
http://www.ekmmetering.com/information/ ... guide.html
There is a section for software. Also stay tuned for our next version of the software, we hope to have this in a couple months.
I will go over it with you here:
This is for help with Free Version or Paid Version of the EKM Reader Software v.3 This version does have some strange interactions with Windows 7 (it works well for some and not well for others)
It sounds like you have our meters here at EKM still in your software. They are there for demonstration purposes.
1. Lets first erase the demo meters and put in your own meter information:
In the main window of the EKM Reader software select the line where the demo meters are in the lower listbox. Select the Meter number and change it to your meter number. Your meter number is laser marked into the face of your meter.
You can select an entire row and delete it by hitting "backspace" or "delete" depending on your system. If you need a new row go up to "Edit" and select "Add Row Below"
2. Go to "Preferences" in the menu bar at the top of the page.
Select "COM Port Setup"
Enter your Communication Device details.
Go to line 3 of this window (lines 1 and 2 have the sample settings)
In your case you have an EKM iSerial (select iSerial) and an EKM Omnimeter (select v.3 meter type). Put in the IP address that you have chosen : 192.168.1.125
Click "Save"
3. Go back to the main window.
Enter your meter number in the field next to the "Read One Meter" Button. Enter 3 in the COM# field (this is because you entered the Communications Device details on line 3 of the COM Port Setup window).
Click "Read One Meter".
The details of your meter reading will fill into the main section in the middle of the window. Wait until it is finished updating before you click "Read One Meter" again.
4. Enter the meter details in the lower listbox.
Use COM# or TCP# 3 , Give your meter a name, and be sure the Meter Number is correctly filled in. Select "Save" from the upper menu. Add more meters by selecting "Add Row Below" under "Edit" in the upper menu bar.
Click "Read all meters"
Each meter will be read in turn from the lower listbox. A successful read will mark an "OK" an unsuccessful read will mark an "!!" or and "X"
Select "Save" again (always a good idea)
Best regards,
