how to reset an EKM omnimeter pulse v4
Posted: Thu Mar 08, 2018 4:29 pm
by Jona_05
how to reset an omnimeter v4 to factory values, since when making the modifications of the meter this is stuck and I can not see it neither in the ekm push nor connecting it directly to the pc, I would greatly appreciate your help !!!!
Re: how to reset an EKM omnimeter pulse v4
Posted: Thu Mar 08, 2018 4:58 pm
by Jona_05
modify the imp / kwh from 800 to 1600 and after that I have not been able to enter the dash of the meter, the meter screen remains in a single value all the time I imagine this stuck, what can I do?
Posted: Mon Mar 12, 2018 11:56 am
Hello Jona,
There is no way to set a meter back to factory defaults.
What CT Ratio is your meter set to? (also, what model of Current Transformers are you using?)
Did you use the EKM Dash to set your meter or your own software?
Have you tried power cycling your meter?
