EKM Dash on Linux won't run
Forum is open to all other questions, answers, and discussions that have no other topic.
dandelot
Post by dandelot »
Received water meter , Pulse V.4, iSerial yesterday.
Set up iSerial appropriate for my LAN.
Hope this is an appropriate place to post this.
Running Ubuntu 14.04 Linux. First attempt to start Dash:
Got a panel appearing with:
Unexpected Error
App.Event_Open
Delegate.Invoke
Application._CallFunctionWithExceptionHandling
REALbasic._RunFrameworkInitialization
And on executing 'EKM Dash":
q2 888: ./runekmdash
Unhandled exception: NilObjectException
Free Trial Timer Action
So: no way to start Dash. Hmmm.
A request:
Please, for Linux, name the application EKMDash with no spaces.
And name the library directory 'EKMDashLibs' with no spaces.
Having spaces in names of any file or
directory is just a pointless pain (with
Linux).
Thanks.
David Anderson
Re: EKM Dash on Linux won't run
Hello David, welcome to the forum and thank you for your questions.
1) What version of Dash are you using?
2) Are you using 32-bit or 64-bit linux?
We tested the same version of Ubuntu (14.04) and we did run into a problem at startup. We needed to install webkit with this command:
sudo apt-get install libwebkit-dev
However, the errors we receive do not match the same errors you are reporting. Please let us know if this gets you going.
