1. Away to enter the reading from the mechanical counter on water or gas meters.
Software could deduct counter reading and use this as an offset. Software would then add this offset to the updateing pulse count which then could display a value that is in sync with mechanical counter. In the event of a power outage or if the counter stops updating you can detect the error and resync it by entering the current mechanical reading.
2. A way to disable the password for those of us who don’t need it or want it.
Or a way to recover the password,
Meter is severely hobbled if pass word is corrupted.
3. A way to upgrade the firmware in the field via internet download. This would keep meter from becoming obsolete. This would protect the customer’s investment when a new feature are added or errors discovered and corrected.
4. Away to disable the 3rd line input from the Line 1 & 2 totals. This with an additional current xformer then could be used to monitor a single circuit that you might be interested in.
5. A way to eliminate on the dash computer screen the data that you have no interest in or need for. Similar to the LCD display feature.
6. A section of fonts and size for the display.
7. Turn the reading to a different color when a preset limit is reached and exists for a fixed time. Email alert is no help for those of us that do not have their units connected to the internet.
