Pulse on the 25IDS
Posted: Wed May 23, 2012 4:16 pm
by Wouter
I presume the pulse comes off port 4 and 6?
Wouter
Re: Pulse on the 25IDS
Posted: Wed May 23, 2012 5:19 pm
by Wouter
It is 1 and 2. Found it.
Wourwe
Posted: Wed Jan 23, 2013 2:20 am
by phase90
Is the pulse output on the 25IDS an active push-pull type of output or is it an open collector type. If either, what are the specs (voltage, current)?
Or is it a relay contact?
Also, is it isolated from the line voltage? ground?
The data sheet does not seem to indicate what it is.
Posted: Wed Jan 23, 2013 11:25 am
Hello Phase90,
Welcome to the forum!
The Pulse Output of all of our meters (including the 25IDS) is an un-powered "dry contact" closure (though solid state). Electrically the Pulse Output is very similar to the closing of a dry contact switch. The only difference is that in this case the output is polarized Pos+ and Neg - (only passes current in one direction)
Pulse Output Specs: Impulse width=90ms, Voltage 12~27V, current ≤27mA, max lead length: 20m
Let me know if you have any questions,
Regards
Posted: Wed Jan 23, 2013 9:33 pm
by phase90
Thank you for the information. So, as I see it, it acts like an open drain/open collector output with the solid state relay having a MOSFET output. If I use a pullup resistor (1K) to some VCC, the + output will pull it down to the - level (GND in my reading system) and the resistor will pull it back up to VCC when it releases 90 ms later.
You say 12-27V. Having a VCC of 5V or 3.3V should still work? I am planning on using a microcontroller to count pulses.
Posted: Fri Jan 25, 2013 12:01 pm
Hey Phase90,
I would have to say that sounds correct, but I am not well versed in these things. I think the best will be to try it out.
I should probably have said "27VDC max" I am certain your 3.3or 5 VDC will work and will not harm the meter. Our 6 Digit Pulse Counter has a small 1.5V battery on it and it works fine: http://www.ekmmetering.com/ekm-metering ... unter.html
When you have your microcontroller up and running you should share your project here, we would be interested in checking it out!!
