EKM Dash with EKM-25EDS-N v.2
kcchiu
Post by kcchiu » Mon Jun 19, 2017 7:14 am
Greeting ,
I brought the EKM-25EDS-N v.2 couple years ago and I just pull download the latest EKM Dash (free trial) to test it out.
But I keep getting "No responds - check RS485 connections and Meter"
I put in a new wire between the Meter and the EKM iSerial v.2 TCP/IP Ethernet to RS-485 Serial Converter
It still cannot read the meeting.
I can get to web interface of the Serial Converter
I set the URAT RS485 with 1200 , 7 even 1 , no flow
Any help will be appreciated
kcchiu
Re: EKM Dash with EKM-25EDS-N v.2
Post by kcchiu » Mon Jun 19, 2017 7:59 am
]I also noticed that the EKM dash software giving an error "Meter Number is not valid for the selected meter model"
So , it keep saying 2481 is not match with EKM-25EDS-N v.2
I attached my meter photo in this post .
Post by Jameson » Wed Jun 21, 2017 12:04 pm
Yes, the 25EDS-N v.2 is an older meter. I do not even have one here to test with.
When the Dash says this is not a valid meter number and asks you if you would like to fix it, just choose "No I dont want to fix it"
Your iSerial serial settings look correct.
