Different kind of errors reading meters
diana26
Post by diana26 »
Hello!
I am using EKM push and meters, and when I see the data information in EKM API it appears some kind of errors. One is called PERR.NR and I know this code means "no response", but there are some other codes:
PERR.DAT
PERR.RXP
PERR.RXO
I want to know what is the description of each code.
I will be very greatful if you could answer my question!
Thanks! :)
Re: Different kind of errors reading meters
PERR.NR = No Response, this indicates that the meter tried to read the given meter number, but it never heard any response from the meter.
PERR.DAT - data format error, this indicates that the data is messed up somehow, so the Push rejected it. You might see this with a weak 485Bee connection. You should not see this very often at all if you have a hardwired connection from your Push to your meter.
PERR.RXP - serial parity error, also indicates messed up data. You would also see this with a weak 485Bee connection. You should not see this very often at all if you have a hardwired connection from your Push to your meter.
PERR.RXO - serial overrun error, also indicates messed up data. You would also see this with a weak 485Bee connection. You should not see this very often at all if you have a hardwired connection from your Push to your meter.
