Pressure readings
nycentral13
Pressure readings
Post by nycentral13 »
Hi EKM,
I just received my Omnimeter v.4 and I am very excited to get it installed and remotely read the pulsed water meter for our floating restaurant. As you can imagine, an unwatched broken dockside waterline inside a vessel can be a very dangerous situation. But my question is not about measuring flow volume, but about pressure. Is there an easy way to connect a pressure sensor to the Omnimeter to record incoming water pressure? If it is possible, can anyone recommend a particular sensor that has a range from 0 to 50 psi?
Kind thanks,
Eric
Pier 66 Maritime - NYC
Re: Pressure readings
Hi Eric,
Welcome to the forum!
This may be our first metering system installed installed in a floating restaurant!! :lol:
We do not have a way to measure a variable output like a "pressure sensor" that I can think of right off. You could however use a "pressure switch" to monitor your pressure. If you were to get a switch that would make contact at 40 psi (or any pressure that would work well for you) or above this could work:
You would connect the 2 wires from your pressure switch to one of the 3 Inputs of the Omnimeter Pulse v.4. When the pressure was over 40psi in this case the switch would be closed. When you read the Omnimeter Pulse v.4 with your computer, it would report the switch as "Closed". If you ever got a report for "Open" this would mean the pressure had dropped below 40 psi. Let us know if this sounds like a good solution.
You could also consider installing a similar switch in your bilge to monitor the water level.
nycentral13
Thanks for the quick reply.
I was hoping for a solution with a more granular output than on/off at 40psi! Plus I already have plans to fill the other two pulsed inputs into my OmniMeter v.4. One for domestic water coming in from land (as I mentioned already) and the other two to monitor the saltwater pumps that bring water in to flush toilets.
I was originally interested in your meters to measure pulsed outputs, but we have a split electrical system with land power and generator service, so the added functionality of the electrical power measurement, is an added bonus.
Kind thanks,
Eric
