I was unable to login to my meters. I tried a password reset to gain access, but I am not getting the reset email; is there a problem with the Encompass server, or does the password reset request actually go straight to the Push3 device? If the PUSH3 was not connected to the internet for some reason, would there be any way of knowing that remotely?
Encompass.io meter password reset
INTELLECTRIC
- Contact:
Re: Encompass.io meter password reset
Im not sure what is going on. We just tested the password reset and received the password reset email. Will you check your spam folder? Chances are that is where the email ended up.
Yes you can see if your Push3 is online by going to your EKM Push Account Portal and looking if the timestamps are current: https://help.ekmmetering.com/support/so ... unt-portal
or by using your Diagnostics App: https://help.ekmmetering.com/support/so ... ostics-app
