Gas Meter Install- Units Questions
GasnElectric
I want to have my gas meter setup for gallons. Its about 12" W.C. that is being measured running through the meter. would the # be 0.0278?
Re: Gas Meter Install- Units Questions
Our gas meters measure gaseous vapor in cubic feet.
Do you want to measure liquid propane? If so, you can convert liquid propane into gaseous propane. Here is a website that can help you: https://www.elgas.com.au/blog/1675-prop ... rms-ft-usa
Im not sure what you mean by: "would the # be 0.0278?"
