Dash.486
Dash.486
Re: Dash.486
Yes, we are also excited about the potential that the Front-end or Dashboard presents!
We have thought of the previous interface as being the backend and wanted to get it dialed in before we started to make it pretty.
The "Watts" graph should be "Total Power or Total Watts".
Current is now Line 1 only but should probably be changed to "Total Amps" (thanks for spotting this). Volts is the "Volts L1 to Neutral" value. Possibly in the future we would add the option to show either Line 1 amps, Line 2 amps, Line 3 amps, and/or Total amps. Ideally we will have the Dashboard be setup in such a way as you could customize your own interface to your needs. It is going to be cool!
The Dashboard (front-end user interface) as it currently stands is certainly in beta, so keep any ideas you have coming!
