UL or No UL
m1sacs
UL or No UL
Post by m1sacs » Thu Aug 23, 2018 11:12 am
How do i determine if i need the UL version or not? I am installing into a Gas station and i nee to make sure i am getting the right meter.
Re: UL or No UL
Post by Jameson » Thu Aug 23, 2018 11:28 am
Hello m1sacs,
The need for UL listing really depends on your local jurisdiction and building codes. You can ask your local building department if they require it. Many building inspectors like to see the UL mark, even if they dont really need it according to their code. If you are unsure if you will need UL, then it is probably best to get UL.
There are many cases where UL is not needed, but having it can't hurt if you can afford the extra $.
There is no functional difference between the UL Listed Models and the Non-UL Listed models.
m1sacs
Re: UL or No UL
Post by m1sacs » Thu Aug 23, 2018 11:38 am
In your video on how to install it it shows that it was being installed in a UL Box, would that cover it even if I got a non UL version of your meter?
m1sacs
Re: UL or No UL
Post by m1sacs » Thu Aug 23, 2018 11:43 am
I also have these type of retail store all across the USA and obviously like any company cost is a big deal, now since its probably going into a panel of some sort anyways if i got a UL panel which is less than the difference in price of the UL to non UL meter i would want to go that route.
Re: UL or No UL
Post by Jameson » Thu Aug 23, 2018 11:45 am
No the UL Listed Enclosure would just be part of a UL Listed installation. It would not be a UL Listed install if you did not use a UL Listed meter inside the UL Listed Enclosure.
For a UL Listed Install you have to use a UL Listed Enclosure, UL Listed Fuse Holders, and a UL Listed Meter, along with UL Listed wire and fittings.
