Firmware for iSerial v.2
mefrosty
Post by mefrosty »
is there a link somewhere for the iserial firmware and serial port drivers?
I have an iserial v2 from '08 and have finally got some time to try and getting it working again
Cheers, Ian.
BlueHornet
Re: Firmware for iSerial v.2
Post by BlueHornet »
Hi Ian,
This might be of use to you. If for any reason you can't download it just PM your email address.
ATC-1000 TCP_IP Converter exe_NetUART_v1.43.rar
(113.16 KiB) Downloaded 1559 times
Here is the latest version of the EKM iSerial firmware (v.1.44.3.1) for those who would like it.
flash_v.1.44.3.1.rar
EKM Metering iSerial Firmware v.1.44.3.1 April 2013
(63.17 KiB) Downloaded 1384 times
(this is a .rar file that may be best handled on a PC)
Fixes an issue with high latency networks, and some reliability issues.
dgraetz
Post by dgraetz »
I tried to update the firmware on my iserial and I'm stuck with this image, I get "Please use correct binary file!" Tried safari and firefox as well.
Now it's stuck
F/W
Select the image file:
http://192.168.0.10
That does not sound good. I dont have experience with this, it does not sound good. Are you able to log into the iSerial at all? Can you see it if you run the VCOM software on a PC?
VCOM software link is about halfway down this page: http://www.ekmmetering.com/information/ ... links.html
