EKM WAN communication
Arturo
Post by Arturo »
I have an Omnimeter V.3 installed at home. Im using EKM Dash software to comunicate and its runs very good when I am inside the LAN area. However I tried to comunicate from outside the LAN and I can´t. What I did I open the port 50000 in the modem and write the public IP of my modem and the same port 50000 in the EKM Dash meter set up.
Could I have some help on this..
Arturo
Re: EKM WAN communication
Hello Arturo,
Thank you for using our meters.
It sounds like you have the networking concepts correct and that you can read your meters over your LAN.
Do you have a Static IP or a Dynamic IP address? You can verify your public IP address by going to: http://www.whatsmyip.org/
Are you able to Ping your IP? Are you able to perform a Port Scan to verify that the port is open?
Please get back to us and we will get you up and running.
