EKM Push Realtime Widget
Posted: Thu Jan 03, 2013 2:09 pm
by Searchman
Please explain the readings on the EKM Push Widget.
The options on the bottom of the widget have three buttons. 100-500-1000. What do these # represent?
What is the vertical scale? None shown on my widget.
At times the color coded line graph disappears. Is this normal?
Re: EKM Push Realtime Widget
Posted: Thu Jan 03, 2013 4:15 pm
Searchman,
The first iteration widget (using live EKM Push Data) on our homepage has a variable scale, if the watts are 100 or 1,000,000 the graph will self adjust to fit.
The 100, 500, and 1000 button is for how many of the latest meter reads you want to view. Click on any of these to essentially zoom in or zoom out to see the data that is most pertinent to you.
Hover your cursor over any of the lines or data points to see the actual value of the datapoint (admittedly this does not always work, hence the first iteration)
If you click on the Watts, Volts, Amps, or Power Factor buttons, you can make each line appear or disappear so that you only see the data that is interesting for you.
We are working on version 2 of the widget that will be even better. Stay tuned ;)
Posted: Wed Jan 16, 2013 3:12 pm
You may have noticed that we have a new version of the widget that is a major improvement over the first one. Here is the widget for the latest 1000 reads, from Omnimmeter 10068, with EKM Push Key MTAxMDoyMDIw
http://widget.ekmmetering.com/EKM2/?rea ... eter=10068
If you look at the URL above you can see how to recreate the link above using your own EKM Push account and meter number. One nice part about this is you can create your own URL to give you the data you want and then bookmark it in your Web Browser or on your Smart Phone to be able to see your own meter data whenever you want.
If you wanted to change the meter number to 10054 (a meter on once per minute reads) for example you would use:
http://widget.ekmmetering.com/EKM2/?rea ... eter=10054
This is LIVE meter data!
Mouse over any portion of the graph to see the actual value of each given data point. Or click 100, 500, or 1000 to see the latest 100, 500, or 1000 meter reads. Click "Show Table" to see live data. Or "Show Range" to see the highs and lows currently being represented on the graph. Very nice!
There is a little window with colorful buttons, click on any of these buttons to make the value appear or disappear.
We hope our EKM Push users find this widget to be helpful and are including it Free of Charge.
Posted: Wed Jan 16, 2013 5:18 pm
by efor
Hi
Just tried the new Widget and :D love it
Keep up the good work
Cheers Ian
Posted: Wed Jan 16, 2013 6:13 pm
by efor
Hi
With the Widget graphs is there any way that the display can be in the corresponding time zone to the user as i am in Australia with a 10 time difference ??? :? :?
Posted: Thu Jan 17, 2013 5:12 pm
Hello Ian,
Welcome to the Forum.
Glad to hear you like the widget! :lol:
We use UTC (Coordinated Universal Time) or GMT for the widget.
Here is some more information about UTC Time: http://en.wikipedia.org/wiki/Coordinated_Universal_Time
https://www.google.com/search?q=utc+time
We will look into seeing if the widget can be made to use your local time.
