Relay Control with Omnimeter v4
Posted: Wed Feb 13, 2013 8:20 am
Is it possible to control the relay function of the Omnimeter through the EKMDash in such a way that:
1. Switching on or off the relay at different time zones
2. Switching on or off the relay when a peak or maximum demand has been reached (Level set through Dash per meter)
3. Scenario: 150 meters connected inline. Each meter measures electricity usage and each meter has 1 relay function to switch on and off 1 appliance (ie. boiler)
The power is cut through a power failure. After 1 hour power is restored resulting in all 150 boilers switching on at the same time, resulting in a sudden max peak demand.
This max peak demand is than used to charge the client.
Can you modify the Dash in such a way that we can through grouping the 150 units in soft starting the boilers. That is if a power failure is detected, the omnimeter
switches all relay controlled appliances off and than switches the groups time delayed on.
Jens
Jens
