amp reading on dash software and push widget
Posted: Tue May 21, 2013 4:25 am
by tremors834
Do the Dash software and/or the Push widget give separate amperage readings for each leg? Or is it a combined total for all legs?
Thanks, Gene
Re: amp reading on dash software and push widget
Posted: Tue May 21, 2013 9:06 am
Hello Gene,
The Omnimeters will all respond with an amps value on Line1, Line2, and Line3. (they also respond with watts, volts, and power factor on each line)
The EKM Dash reports amps on Line1, Line2, and Line3 for each meter read.
The EKM Push data contains values from Line1, Line2, and Line3.
The EKM Push widget only displays amps Line1 on the graph. If you click the "show Table" button you will get a display of Amps on Line1, Line2, and Line3
Posted: Tue May 21, 2013 9:48 am
by tremors834
Thanks Jameson,
Any chance the widget will have the option to display L1, L2 and L3 in the future??
Posted: Tue May 21, 2013 10:29 am
I would say yes, absolutely. We would like to enhance the widget and the way that we display Push data online.
For now the widget is only meant to be a sample of the potential functionality of the Push data and the Push system. The best way to see all of your Push data at this point is to use the EKM Dash to retrieve your Push data.
We will always be working on improving the way that we display data, help you save energy, and create bills. If you have any particular needs, we are all ears :!:
