Data value Limits
miquel
Data value Limits
Post by miquel »
Hi
My question is: What happens when a Omnimeter I v.3 value, for example 8Bytes Total kWh, reach it's limit?
I know that is a very long value, but I have to know in order to develop the software and to be reliable for big production plants and for lot of years.
So, what happens when Total KWh reach 9.999.999,9 ?
Re: Data value Limits
Hello Miquel,
If an Omnimeter were to measure 9,999,999.9 kwh (this is very roughly 2 million dollars worth of electricity) it would roll over to zero and keep going. If you are thinking you are going to install in this kind of a situation, you can consider using our Omnimeter Pulse v.4. This meter uses a decimal place that shifts for larger CT ratios. So if you were to use 3000 amp CTs (0 decimal places in the kWh values, this is a value that is reported in the v.4 return string) for example, you would have a maximum kwh measurement of 99,999,999 kWh.
Please let us know if you have any questions,
miquel
Post by miquel »
Thanks for your response.
I don't think I can reach easily this value, but, as I'm just in beta version of the software, I'd like to design it the best way.
