EKM Dash update and problem
Posted: Mon Sep 09, 2013 6:51 pm
by alfredbhulai
Hi EKM,
Last week an update offer for the EKM Dash appeared on my laptop and I accepted. When I subsequently attempted to adjust the view, the meter names and numbers disappeared off the window to the left. Nothing I tried was able to get it back in view. I even deleted the program and downloaded it afresh. I reset and that did not work either. The laptop probably retained some memory it liked of what I don't want. I scrutinized the blog but found nothing like this.
Please help, because I couldn't choose any meter to see their readings.
Fortunately, other computers elsewhere have the meters in the usual way, but I can no longer read any of my clients' systems remotely on my laptop.
Alfred
Re: EKM Dash update and problem
Posted: Wed Sep 11, 2013 9:06 am
Hello Alfred,
Thanks for letting us know! We are looking into this and hope to have a fix in our next release.
For now you can try sending us a "Diagnostic Email" (this is under the Help menu item). We can then take a look at your files to see where they may be corrupted.
We would then hope to have a fix included in the next release of the Dash.
Thanks for your help,
Posted: Wed Sep 11, 2013 9:32 am
by alfredbhulai
Thanks, Jameson.
I did send a diagnostic email.
I'll send another, but it won't have the meters because I deleted everything in attempting a fresh start.
Alfred
Posted: Wed Sep 11, 2013 10:03 am
by alfredbhulai
I could not send another diagnostic email today because a Progress window said,
"Error, could not submit diagnostic information."
Alfred
2011-09-11
Posted: Wed Sep 11, 2013 10:56 am
I am not sure why this would be.
The first question that comes to mind is: Does your computer have a connection to the internet? You need a connection to the internet in order to send us the diagnostic files.
Posted: Mon Sep 16, 2013 7:42 pm
by alfredbhulai
Yes it does have connection to internet and was connected, sending and receiving emails. I'll try again.
Posted: Tue Sep 17, 2013 5:49 pm
by alfredbhulai
I succeeded in sending the diagnostic info.
Alfred
Posted: Thu Nov 28, 2013 5:37 pm
by Gary
Yesterday I downloaded and did a new install of Dash, same as the original poster, and I lost my view of the meter also. In my case it was because I'd re-sized the regions to the point that the meters section disappeared. I have also tried to re-install to no avail. There must be some other location within some folder that holds the configuration info, since doing a fresh install still held the old info. I have sent a diagnostic email prior to finding this post, but its the same issue.
I'll try and do an install on a Linux box and see how that goes. I look forward to a solution, as the Dash interface on my PC is at present unusable.
Posted: Tue Dec 03, 2013 2:29 pm
Hello Gary,
I would try removing your EKM Dash prefs file (it sounds corrupted), when you restart your Dash it will build a new one. This is where your windows positioning and sizing is stored.
Here is the location of the Dash prefs file for various operating systems:
Windows 7 and Vista: C:\Users\USER\AppData\Roaming\EKM Dash
Mac OS X: User/Library/Application Support/EKM Dash/
Let me know if this does not help, or better yet, let us know if it does help.
Posted: Thu Jan 16, 2014 12:54 pm
by alfredbhulai
Jameson,
It fixed my problem, as I described in a post I saw with the same fix. Thanks!
Now I can get on with other problems to worry you with.
Alfred
