V4 Push 2 & Dash on RS485 Loop
Posted: Tue Jan 27, 2015 2:41 am
Not sure how they would co exist.
Now that you have v4's able to work with push, I want to put V4 push 2 on my want list, but need to know if they play well together sharing the 485 loop.
I understand that the push box bridges the RS485 loop.
So how then do you make changes in the EKM box settings. ?
Un plug or cut power to the push box to disable it so Dash can talk to the EKM via 485. ?
How does the dash computer to to talk to the selected EKM box?
When you switch data sources in dash does it shut of the push box data flow?
Does dash have the smarts to override (interrupt) the date flow from EKM to push box.
Do I need to install a DPDT switch to switch between the two. ?
Just trying to a little preplaning and or wiring.
