Which port to use on EKM Omnimeter Pulse v.4
Post by 209 »
I want to connect one 3/4" Water Meter to an Omnimeter Pulse v.4. Which port should I connect the water meter to?
Apologies if this has been asked before?
c
Re: Which port to use on EKM Omnimeter Pulse v.4
Here is a page in our support documents that should help you: https://help.ekmmetering.com/support/so ... s-metering
This is a quote from that page:
"For Pulse Input 1, connect the pulse output wire from a water meter or gas meter to port 13 on the Omnimeter Pulse v.4 and the ground wire to port 14 on the Omnimeter Pulse v.4"
Here is the spec sheet for the 3/4" Water Meter: http://documents.ekmmetering.com/EKM-SP ... -sheet.pdf
Here is a quote from that page:
"Connect the red wire from the water meter to either port 11, 12, or 13.
Connect the black wire to port 14."
