EKM Dash setup on Linux
Posted: Tue Nov 08, 2016 8:40 pm
I'm trying to install EKM Dash software on Ubuntu 14.04, and get a crash when starting the software.
It is 64bit os and already used the following steps to install the libraries:
Here's a log of what happens when I run it:
sudo dpkg --add-architecture i386
sudo apt-get install libc6:i386 libncurses5:i386 libstdc++6:i386 libgtk2.0-0:i386Thanks for any help.Runtime Error
Please report what caused this error along with the information below.
RuntimeCore/ICUStable.cpp: 79
Failure Condition: sLibraryPtr
Could not load ICU library
(process:17190): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(process:17190): GLib-GObject-CRITICAL **: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(process:17190): Gtk-CRITICAL **: IA__gtk_settings_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
(process:17190): GLib-GObject-CRITICAL **: g_object_get: assertion 'G_IS_OBJECT (object)' failed
(process:17190): GLib-GObject-WARNING **: value "TRUE" of type 'gboolean' is invalid or out of range for property 'visible' of type 'gboolean'
(process:17190): Gtk-WARNING **: Screen for GtkWindow not set; you must always set
a screen for a GtkWindow before using the window
(process:17190): Gdk-CRITICAL **: IA__gdk_pango_context_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
(process:17190): Pango-CRITICAL **: pango_context_set_font_description: assertion 'context != NULL' failed
(process:17190): Pango-CRITICAL **: pango_context_set_base_dir: assertion 'context != NULL' failed
(process:17190): Pango-CRITICAL **: pango_context_set_language: assertion 'context != NULL' failed
(process:17190): Pango-CRITICAL **: pango_layout_new: assertion 'context != NULL' failed
(process:17190): Pango-CRITICAL **: pango_layout_set_text: assertion 'layout != NULL' failed
(process:17190): Pango-CRITICAL **: pango_layout_set_attributes: assertion 'layout != NULL' failed
(process:17190): Pango-CRITICAL **: pango_layout_set_alignment: assertion 'layout != NULL' failed
(process:17190): Pango-CRITICAL **: pango_layout_set_ellipsize: assertion 'PANGO_IS_LAYOUT (layout)' failed
(process:17190): Pango-CRITICAL **: pango_layout_set_single_paragraph_mode: assertion 'PANGO_IS_LAYOUT (layout)' failed
(process:17190): Pango-CRITICAL **: pango_layout_set_width: assertion 'layout != NULL' failed
(process:17190): Pango-CRITICAL **: pango_layout_get_extents: assertion 'layout != NULL' failed
(process:17190): Gtk-CRITICAL **: IA__gtk_icon_theme_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
(process:17190): Gtk-CRITICAL **: IA__gtk_icon_size_lookup_for_settings: assertion 'GTK_IS_SETTINGS (settings)' failed
(process:17190): Gtk-WARNING **: Invalid icon size 6
(process:17190): Gtk-CRITICAL **: IA__gtk_icon_theme_load_icon: assertion 'GTK_IS_ICON_THEME (icon_theme)' failed
(process:17190): Gtk-WARNING **: Error loading theme icon 'dialog-error' for stock:
(process:17190): Gtk-WARNING **: /build/gtk+2.0-B1ahdU/gtk+2.0-2.24.23/gtk/gtkstyle.c:2358: invalid icon size '6'
(process:17190): Gtk-CRITICAL **: IA__gtk_style_render_icon: assertion 'pixbuf != NULL' failed
(process:17190): GLib-GObject-CRITICAL **: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
(process:17190): Pango-CRITICAL **: pango_layout_set_wrap: assertion 'PANGO_IS_LAYOUT (layout)' failed
(process:17190): GLib-GObject-CRITICAL **: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
(process:17190): Gdk-CRITICAL **: IA__gdk_screen_get_width: assertion 'GDK_IS_SCREEN (screen)' failed
(process:17190): Pango-CRITICAL **: pango_layout_get_line_count: assertion 'layout != NULL' failed
