Dear EKM support/Jameson,
The issue of Omnimeter V4 not counting pulses, but does show Pulse input state correctly (and changing from "open" to "closed" and back) has been reported already extensively on this forum. The solution is to flash new firmware on the meter.
Unfortunately my iSerial is no longer usable (it is hanging on a firmware update, which never installed somehow). Instead I bought the EKM Push system. At present I cannot get at the meter (7000 km away from my current residence) however, my dear wife is at the premises where the meter is installed.
Questions:
0.) I am assuming this is indeed the recommended solution (new firmware).
1.) Would there be a short term fix (e.g. switch the power to the meter on-off-on-off-on) that I can ask my better half to execute such that perhaps the meter works as intended again until this issue re-emerges? (the meter worked fine for a long time)
2.) How would I best go about fixing/installing the firmware at a later opportunity - when I am at the premise and can tinker with the EKM meter/Push (or even try to get the iSerial to work again).
Support much appreciated,
With regards
Piet van Mastrigt
Re: Omnimeter V4 not counting pulses
Sorry to hear that v4 meter is giving you trouble, yes pulse counts would sometimes lockup after a power glitch with early versions of the v4 firmware. If there was an arc in the line or some other weird anomaly the pulse counts would quite annoyingly lockup
The simple quick solution is to power cycle the meter. Just disconnect power to the v4, then power it back up. It should start counting pulses right away.
The more permanent solution is to ship the v4 meter to us and we can fix it here, and if not we would just ship you a free replacement. The latest v4 firmware does not have this issue at all.
Sorry for the trouble, hopefully we can get this fixed for you in as pain free a way as possible.
Best,
Best,
Hello Jameson, thanks for the tip and the pledge. Though the meter was power cycled already as a test before it did work this time and the counters are going - thanks a lot.
I plan to ship the meter for a firmware upgrade per your advice, however, I think this will only be possible somewhere Q3 next year for logistical reasons.
With regards
Piet van Mastrigt
With regards
Piet van Mastrigt
