EKM Dash on Linux won't run
dandelot
Post by dandelot » Sat Sep 06, 2014 9:52 am
Received water meter , Pulse V.4, iSerial yesterday.
Set up iSerial appropriate for my LAN.
Hope this is an appropriate place to post this.
Running Ubuntu 14.04 Linux. First attempt to start Dash:
Got a panel appearing with:
Unexpected Error
App.Event_Open
Delegate.Invoke
Application._CallFunctionWithExceptionHandling
REALbasic._RunFrameworkInitialization
And on executing 'EKM Dash":
q2 888: ./runekmdash
Unhandled exception: NilObjectException
Free Trial Timer Action
So: no way to start Dash. Hmmm.
A request:
Please, for Linux, name the application EKMDash with no spaces.
And name the library directory 'EKMDashLibs' with no spaces.
Having spaces in names of any file or
directory is just a pointless pain (with
Linux).
Thanks.
David Anderson
Re: EKM Dash on Linux won't run
Post by Jameson » Tue Sep 09, 2014 11:38 am
Hello David, welcome to the forum and thank you for your questions.
1) What version of Dash are you using?
2) Are you using 32-bit or 64-bit linux?
We tested the same version of Ubuntu (14.04) and we did run into a problem at startup. We needed to install webkit with this command:
sudo apt-get install libwebkit-dev
However, the errors we receive do not match the same errors you are reporting. Please let us know if this gets you going.
