EKM Dash iSerial IPv6 connectivity
Posted: Wed Dec 27, 2023 8:37 pm
Hi, I would like to ask about possibility of using IPv6 stack for the iSerial emulation.
Script (for IPv4):
Script (for IPv6):
to start the server on the host, which is connected to the meter over RS485.
Connection over IPv4 is fine, I'm able to communicate with the meter.
IPv6 results in "300003101 Bad Connection to iSerial".
I verified that the TCP port is open in both cases (IPv4 & IPv6).
Please advise if I'm doing something wrong here. Thanks.
Script (for IPv4):
Code: Select all
socat TCP-LISTEN:50000,reuseaddr,fork,max-children=1 file:/dev/ttySC0,raw,b9600,csize=2,nonblock,echo=0Code: Select all
socat TCP6-LISTEN:50000,reuseaddr,fork,max-children=1 file:/dev/ttySC0,raw,b9600,csize=2,nonblock,echo=0Connection over IPv4 is fine, I'm able to communicate with the meter.
