Mounting the 8 Digit Pulse Counter in a Standard Cover Plate
Posted: Mon Mar 31, 2014 5:20 pm
How to mount your 8 Digit Pulse Counter in a standard wall cover plate.
1) Buy a wall cover plate that has widely spaced mounting holes (about 3 1/4" inches apart, not 2 3/8" like a regular light switch cover)
2) Mark the opening you will make. We used 22.2 mm x 45 mm
3) Use a router to cut the opening and a file to square up the corners and make the finishing touches.
4) Shot of the back
5) You could easily fit 2 Pulse Counters in 1 cover plate if you needed to.
Here is a link to the 8 Digit Pulse Counter on our website: http://www.ekmmetering.com/ekm-metering ... ter-8.html
Thanks, let me know if this was helpful :?: :?:
Re: Mounting the 8 Digit Pulse Counter in a Standard Cover Plate
Posted: Tue Oct 13, 2015 3:11 pm
The link in the post above is broken.
Here is a link to the 8 Digit Pulse Counter product page: http://www.ekmmetering.com/8-digit-pulse-counter.html
Here is a link to the 8 Digit Pulse Counter spec sheet: http://documents.ekmmetering.com/Eight- ... -Sheet.pdf
