Example accessing meter
dandelot
Post by dandelot » Sat Oct 18, 2014 4:05 pm
I've put example code which accesses my EKM water meter in
http://www.prevanders.net/ekmexample.tar (the tar file
comtains C and Python source). It is written for Linux/Unix
but might be of some value for people using other OS's.
Source license is BSD.
http://www.prevanders.net/water.html
shows a little bit of how I use the resulting data.
dandelot
Re: Example accessing meter
Post by dandelot » Mon Oct 20, 2014 2:04 pm
That tar file is now gone, a bit out of date.
The water.html page links to an updated tar file.
wbingham
Post by wbingham » Wed Sep 16, 2015 12:22 pm
Dandelot- I am a developer (PHP, JS mostly) and am super interested in more details about your ekm water meter project. Would you be willing to share you hardware setup- I grabbed your tar file already-
I run an ESXi stack out of my house and have lots of dev boxes up and running to host code. Stuck at the physical nature of how you hooked things (serial-to-ethernet converter) up.
MohaveTom
Post by MohaveTom » Thu Sep 24, 2015 9:57 am
This is a link to a post in this forum for an example accessing EKM meters using C++.
http://forum.ekmmetering.com/viewtopic ... t=30#p6339
