Using Omnimeter II UL3.0 to measure usage and export
Posted: Mon Aug 13, 2012 7:10 am
I have a single phase switchboard (230V - Australia) with a standard supply and a controlled supply and a solar inverter for feeding back into the grid.
The Omnimeter II UL v.3 in a 3 phase 4 wire configuration appears to be what I'm after to measure the standard supply, the controlled supply and the output from the inverter. As far as I can see this will work but I can't see if the meter transmits the data from the three sources or only for the three combined. The combined display on the meter I suspect will be incorrect unless the clamp is correctly orientated on the inverter output so the arrow points towards the switchboard?
Is this meter going to achieve my goal of being able to access the raw data from each of these power sources and does the software allow you to see each of the power sources or just one aggregate?
