Dash.486
Posted: Wed Mar 13, 2013 11:31 pm
by Nevland
Love the new Dash Board. I was going to post a Dash wish list. (
A way to eliminate from the on screen read out all the info you didn't need and larger type face for the data you do need. User choice.) The Dash Board may make my wish list unnecessary.
Not sure of what the read outs are though. Watts look like it is the sum of L1 and L2. Volts Line 1 ? Amps seem to L1 only. Hopefully you will also include Line 2 info.
Re: Dash.486
Posted: Thu Mar 14, 2013 2:14 pm
Yes, we are also excited about the potential that the Front-end or Dashboard presents!
We have thought of the previous interface as being the backend and wanted to get it dialed in before we started to make it pretty.
The "Watts" graph should be "Total Power or Total Watts".
Current is now Line 1 only but should probably be changed to "Total Amps" (thanks for spotting this). Volts is the "Volts L1 to Neutral" value. Possibly in the future we would add the option to show either Line 1 amps, Line 2 amps, Line 3 amps, and/or Total amps. Ideally we will have the Dashboard be setup in such a way as you could customize your own interface to your needs. It is going to be cool!
The Dashboard (front-end user interface) as it currently stands is certainly in beta, so keep any ideas you have coming!
