10 amp current transformer
Posted: Sat Feb 18, 2012 9:10 am
Hello,
I want to monitor the power consumption from my 3 heatpumps, they are 230V 1,6Kw +/- 6Amp each.
I want to use one 3 phase meter and connect each heatpump to one phase.
The smallest current transformer is 100Amp and i think with the max current i draw (6Amp) at each phase it will not be verry accurate, especially low currents when the pump takes 1 Amp on low power .
I can put the wire 5 times like a coil through the currenttransformer to get 5:1 but in the software i cannot go lower then 100Amp.....why?
Would be good if we could give the software our own currenttransformer scale,then we can use it for all power range
Is there a way to solve this?
Robert
Robert
