Pressure readings
Posted: Mon May 13, 2013 10:58 am
Hi EKM,
I just received my Omnimeter v.4 and I am very excited to get it installed and remotely read the pulsed water meter for our floating restaurant. As you can imagine, an unwatched broken dockside waterline inside a vessel can be a very dangerous situation. But my question is not about measuring flow volume, but about pressure. Is there an easy way to connect a pressure sensor to the Omnimeter to record incoming water pressure? If it is possible, can anyone recommend a particular sensor that has a range from 0 to 50 psi?
Kind thanks,
Eric
Pier 66 Maritime - NYC
Kind thanks,
Eric
