Use Dashboard
dmarks
Use Dashboard
Post by dmarks »
The meters I'm using are simple and easy to set up , however I would like to have my own dashboard.
This dash should allow me to view all the meter at once , with fields that I select. eg. I will have all 12 meters showing realtime Amps on one screen.
Deon Marks
Re: Use Dashboard
Hello Deon,
Welcome to the forum!!
It sounds like http://www.encompass.io will be perfect for your needs. Encompass is our new web based dashboard, it uses data from our EKM Push system. We just loaded a new updated version yesterday. Encompass.io is still in beta and is heavily under development, so is not really promoted on our our website yet. If you have any feature requests, please let us know.
You can certainly set it up so that you can see data from 12 different meters simultaneously.
We will also be continuing to improve our EKM Dash software and would hope to have much better dashboards in the future.
Here is a bit more information: http://forum.ekmmetering.com/viewtopic.php?f=16&t=3321
Screenshot 2014-08-01 09.16.42.png (162.94 KiB) Viewed 7949 times
